  4. DC DC 2W
  5. A2405S-2WR3/A2403S/A2412S/A2415S/A2424S-2WR3 Dual output 24V to 3.3V/5V/9V/12V/15V/24V 2W DC to DC power module/converter
    $0.99
A_S Series Mode list
3. Low static current and high conversion efficiency
4. Ripple/noise (20MHz bandwidth): 30mVp-p (Typ.)
Ripple & Noise30/80(max)Mvp-p
Input current (full load/no load)5VDC Input Series--454/5--/10m'A
9VDC Input Series--250/5--/10
12VDC Input Series--186/2--/5
15VDC Input Series--148/2--/4
24VDC Input Series--92/1--/2
Reflection ripple current
--15--m'A
Impulse voltage3.3VDC Input Series-0.7--5VDC
5VDC Input Series-0.7--9
9VDC Input Series-0.7--15
12VDC Input Series-0.7--18
15VDC Input Series-0.7--21
24VDC Input Series-0.7--30
Output Voltage AccuracySee Error Envelope Curve----±15.0%
Linear adjustment rateInput voltage variation ±1%3.3V Input----±1.5%
others----±1.2%
Load adjustment rate10%~100% load3.3VDC Output--18--%
5VDC Output--12--%
9VDC Output--8--%
12VDC Output--7--%
15VDC Output--6--%
24VDC Output--5--%
----±0.03%/℃
Cout CapacitanceFilter capacitorRefer to usual application
