  4. DC DC 2W
  5. 24V to 5V 2W 400mA DC to DC Isolation Voltage 1500VDC Power Module Converter B2405S-2WR3
    $1.35
B24XX-2W Series Mode list
3. Low no-load power consumption 0.025W(Typ.)
Ripple & Noise30/80(max)Mvp-p
Input current (full load/no load)5VDC Input Series--454/5--/10m'A
9VDC Input Series--250/5--/10
12VDC Input Series--186/2--/5
15VDC Input Series--148/2--/4
24VDC Input Series--92/1--/2
Reflection ripple current
--15--m'A
Impulse voltage3.3VDC Input Series-0.7--5VDC
5VDC Input Series-0.7--9
9VDC Input Series-0.7--15
12VDC Input Series-0.7--18
15VDC Input Series-0.7--21
24VDC Input Series-0.7--30
Output Voltage AccuracySee Error Envelope Curve----±15.0%
Linear adjustment rateInput voltage variation ±1%3.3V Input----±1.5%
others----±1.2%
Load adjustment rate10%~100% load3.3VDC Output--18--%
5VDC Output--12--%
9VDC Output--8--%
12VDC Output--7--%
15VDC Output--6--%
24VDC Output--5--%
----±0.03%/℃
Cout CapacitanceFilter capacitorRefer to usual application
