B2405D-1WR3 DC-DC isolated power module B2403/09/12/15/24D-1WR3 single output power converter
Visitor2137
Price$1.20
Fixed voltage input, isolated non stabilized output, power 1W
Isolation voltage 1500VDC/1min, 3000VDC/1s
Low no-load power consumption: 0.025W (TyP.)
Working environment temperature: -40 ℃ C~+85 ℃ C
Efficiency up to 91%
Output short circuit protection: sustainable short circuit protection, automatically restoring international standard pin mode
Small SIP packaging
Low ripple/noise (20MH bandwidth): 30mVp-p (tyP.)
Over temperature protection and output sustainable short circuit protection ROHSMTBF ≥ 3.5 million hours (3500000 Hrs)
Input current (full load/no load) | 3.3VDC Input Series | -- | 378/8 | -/15 | m'A |
5VDC Input Series | -- | 227/5 | --/10 | ||
12VDC Input Series | -- | 93/2 | --/5 | ||
15VDC Input Series | -- | 74/2 | --/4 | ||
24VDC Input Series | -- | 46/1 | --/2 | ||
Impulse voltage (lsec.max) | 3.3VDC Input Series | -0.7 | -- | 5 | VDC |
12VDC Input Series | -0.7 | -- | 16 | ||
15VDC Input Series | -0.7 | -- | 20 | ||
Output Voltage Accuracy | See Error Envelope Curve | -- | -- | ±15.0 | % | |
Linear adjustment rate | Input voltage variation ±1% | 3.3V Input | -- | -- | ±1.5 | % |
others | -- | -- | ±1.2 | % | ||
Load adjustment rate | 10%~100% load | 3.3VDC Output | -- | 15 | 20 | % |
5VDC Output | -- | 10 | 15 | % | ||
9VDC Output | -- | 8 | 10 | % | ||
12VDC Output | -- | 7 | 10 | % | ||
15VDC Output | -- | 6 | 10 | % | ||
24VDC Output | -- | 5 | 10 | % | ||
Output short circuit protection | Continuous short circuit protection, automatic recovery | -- | ||||
1. Standard Application:
If further reduction of input and output ripple is required, a capacitor filtering network can be connected at the input and output terminals, and the application circuit is shown in Figure 1. However, attention should be paid to selecting appropriate filtering capacitors. If the capacitance is too large, it is likely to cause startup problems. For each output, while ensuring safe and reliable operation, the recommended capacitive load values are detailed in Table 1
Vin (vdc) | Cin(uF) | Vo(Vdc) | Cout(uF) |
3.3/5 | 4.7 | 3.3/5 | 10 |
12 | 2.2 | 9 | 4.7 |
15 | 2.2 | 12 | 2.2 |
24 | 1 | 15 | 1 |
24 | 1 |
Table 1 Recommended capacitive load values for details
2. EMC typical application:
Vin (Vdc) | 3.3/5/12/15/24 |
C1/C2 | 4.7uF/50V |
C3 | See the cout of Table 1 |
LDM | 4.7uH |
CY | 270pF/2KVDC |
Table EMC parameter recommendation
3. Notes:Output Load Requirements
