B1205S-2WR3/B1203S/B1209S/1212S/1215S/1224S-2WR3 DC to DC 12V to 5V 2W 400mA Isolation Voltage 1500VDC Power Module Converter
Visitor1860
Price$0.66
Ripple & Noise | 30/80(max) | Mvp-p |
Input current (full load/no load) | 5VDC Input Series | -- | 454/5 | --/10 | m'A |
9VDC Input Series | -- | 250/5 | --/10 | ||
12VDC Input Series | -- | 186/2 | --/5 | ||
15VDC Input Series | -- | 148/2 | --/4 | ||
24VDC Input Series | -- | 92/1 | --/2 | ||
Impulse voltage | 3.3VDC Input Series | -0.7 | -- | 5 | VDC |
9VDC Input Series | -0.7 | -- | 15 | ||
12VDC Input Series | -0.7 | -- | 18 | ||
Output Voltage Accuracy | See Error Envelope Curve | -- | -- | ±15.0 | % | |
Linear adjustment rate | Input voltage variation ±1% | 3.3V Input | -- | -- | ±1.5 | % |
others | -- | -- | ±1.2 | % | ||
Load adjustment rate | 10%~100% load | 3.3VDC Output | -- | 18 | -- | % |
5VDC Output | -- | 12 | -- | % | ||
9VDC Output | -- | 8 | -- | % | ||
12VDC Output | -- | 7 | -- | % | ||
15VDC Output | -- | 6 | -- | % | ||
24VDC Output | -- | 5 | -- | % | ||
Output short circuit protection | Continuous short circuit protection, automatic recovery | -- | ||||
Cout Capacitance | Filter capacitor | Refer to usual application |
