  4. DC DC 1W
  5. 12V to 12V 1W 84mA DC to DC Isolation Voltage 3000VDC Power Module Converter F1212S-1WR3
    $1.02
F12XX Series Mode list
2. Isolation voltage≤3000VDC
3. Low no-load power consumption 0.025W(Typ.)
Ripple & Noise30/80(max)Mvp-pPure resistive load, 20MHz broadband, peak-to-peak
Related input voltage12Vdc
Input voltage range10.8-13.2Vdc
Maximum input current≤0.3A
Reflection ripple current15mA
DC5V rated input voltage series
Impulse voltage≤9Vdc
Starting voltage4.5Vdc
Start-up delay---msRated input voltage and costant resistance load
Output Characteristics(12v/84mA)
No load rated output voltage12V±15%Vdc
Short-time maximum output current≥94mA
Rated output current84mA
Voltage regulation±1.5%
Load regulation ±12%
Transfer efficiency Vin=24Vdc, output full load 90%
Output grain sweep noise(mVp-p)Pure resistance load, 20MHz bandwidth, peak to peak valuemV
Outputting the maximum voltage 110-160%Vdc
Isolation capacitanceInput- output, 100KHz/0.1V 20pF-
Cout CapacitanceFilter capacitor2.2-10μA/50V
