12V to 9V 1W 111mA DC to DC Isolation Voltage 3000VDC Power Module Converter F1209S-1WR3
Visitor619
Price$1.06
2. Isolation voltage≤3000VDC
Ripple & Noise | 30/80(max) | Mvp-p | Pure resistive load, 20MHz broadband, peak-to-peak |
Related input voltage | 12 | Vdc | |
Input voltage range | 10.8-13.2 | Vdc | |
Reflection ripple current | 15 | mA | DC5V rated input voltage series |
Impulse voltage | ≤9 | Vdc | |
Starting voltage | 4.5 | Vdc | |
Start-up delay | --- | ms | Rated input voltage and costant resistance load |
Input filter type | Capacitance filter type | ||
Output Characteristics(9v/111mA)
No load rated output voltage | 9V±15% | Vdc | |
Short-time maximum output current | ≥121 | mA | |
Rated output current | 111 | mA | |
Voltage regulation | ±1.5 | % | |
Load regulation | ±12 | % | |
Transfer efficiency | Vin=24Vdc, output full load 90 | % | |
Output grain sweep noise(mVp-p) | Pure resistance load, 20MHz bandwidth, peak to peak value | mV | |
Output over-voltage protection | Outputting the maximum voltage 110-160% | Vdc | |
Isolation capacitance | Input- output, 100KHz/0.1V 20pF | - |
